henleyn
#1 Posted : Monday, June 10, 2013 12:14:40 PM(UTC)
henleyn
What is the easilest way to remove a wash cloth blocking drain pump intake on whirlpool cabrio throwing a "Ld" code
Simon / APP Team
#2 Posted : Monday, June 10, 2013 1:34:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Drain the water out of the tub. Disconnect the power and water. Lay the washer on it's front (protect it from scratching). Now you have the excess to the pump. You can ether leave the pump installed or remove it and work at the bench. If you'd like to have a part numbers and diagrams, please provide the complete model number of the unit.
Simon.
henleyn
#3 Posted : Monday, June 10, 2013 4:59:15 PM(UTC)
henleyn
We used a fishing rod and dropped a fish hook with flat weights between the basket and tub. Hooked it and pullled out and pulled a 10 lb wash cloth shaped like a bass.(LOL).:) :) :) :) :)
Thanks for your help
Simon / APP Team
#4 Posted : Tuesday, June 11, 2013 9:35:16 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
How did you cook it?
Did you tape the event?
Simon.
