sherfield2002
#1 Posted : Monday, June 10, 2013 7:36:54 AM(UTC)
sherfield2002
I'm having a problem with my Roper dryer and don't know if it might be the motor or timer.
Sometimes when I turn the timer knob to a setting to begin a load(any setting or temp) I get a loud humming noise from the motor, even before pressing the start button. When I turn the knob back to OFF, the humming stops. I can usually turn the timer back to OFF and back to the setting a few times until it doesn't hum when turned to a setting and then press the start button and the dryer starts and runs fine.
Which is probably the problem? The motor or timer?
Simon / APP Team
#2 Posted : Monday, June 10, 2013 9:14:45 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely it is a bad timer Part number: 8299781
Here are the breakdown diagrams and Top and Console parts for Roper REX6634PQ0 - AppliancePartsPros.com
Post the results.
Simon.
