noname87
#1 Posted : Sunday, June 9, 2013 10:47:08 AM(UTC)
noname87
[FONT=Arial","sans-serif]I have a KitchenAid KSRS25RVMK03 refrigerator which has a Whirlpool W10190960 ice maker. The icemaker overflows. I have tried:[/FONT]
[FONT=Arial","sans-serif]1) [/FONT]Replacing the ice maker. The new ice maker also overflows.
[FONT=Arial","sans-serif]2) [/FONT]I removed the new ice maker without disconnecting the wires. When it calls for water, it allows 14 oz of water to flow. This is 6 oz more than the 8 oz needed to fill the tray. Once the water stops, it does not drip.
My water pressure is between 40-60 psi running off a well. I am trying to determine if the new ice maker is defective or if I need a new valve. I do not believe this ice maker allows the flow time to be adjusted but I could be wrong.
noname87
#2 Posted : Sunday, June 9, 2013 5:19:52 PM(UTC)
noname87
Okay I ran a couple of cycle by connecting the ice maker and manually filling the ice tray. I then caught the water coming out of the ice maker valve in a jar. The valve allow 13-14 oz of water for each of three cycles. The cubes did freeze and eject.
This is where it gets interesting. I measured the voltage between black and white on the connector and it measured 88V. Between black and tan, I got 44V. The input voltage to the refrigerator is 122V. Shouldn't the input voltage on bk-wh be 122V.
noname87
#3 Posted : Monday, June 10, 2013 5:28:04 PM(UTC)
noname87
I tried putting the old ice maker back in. Both the old and new are allowing 14 oz of water to flow and takes 23 secs. Does this indicate a valve problem?
frigidaire refrigerator ice maker overflows ice (Refrigerator & Freezer Repair)
by Cee3PeeOh 1/3/2017 11:04:32 AM(UTC)
water dispensor pressed ice maker overflows (Refrigerator & Freezer Repair)
by 3dshooter1 7/29/2012 6:14:10 PM(UTC)
Ice Maker Overflows When Filling (Refrigerator & Freezer Repair)
by hwenger 7/21/2009 3:50:56 PM(UTC)
warm refridge, ice maker overflows, solid ice (Refrigerator & Freezer Repair)
by benson5021 3/18/2008 10:53:36 AM(UTC)
Ice Maker Overflows (Refrigerator & Freezer Repair)
by Capt Steve 11/16/2007 7:48:07 AM(UTC)
