I am looking for control parts for the Amana Wall Oven AEW4630DDB. Technician indicates that it needs a new control and membrane, but the membrane is no longer available. I have been able to find a control panel on line, but nothing referencing a membrane. Any help would be appreciated.
Here are your parts Parts for Amana AEW4630DDB Wall Oven - AppliancePartsPros.comSee the attachment for the tech sheet, I believe they are referring to the control panel (item 1 in the 02 Control Panel section. It includes a membrane type keypad. Strange that you need both usually it is one or the other. The usual way to troubleshoot this is to check the keypad outputs using a meter. Then if they are OK replace the control board. |
THIS FORUM IS DEAD!!!!!!! |
Thank you Denman. Would these be the part numbers then:
Panl-Cntrl by Whirlpool Part Number AP4417518 MFG Part Number 5765M462-60
and
Control, H2 (clock-C by Whirlpool Part Number AP4098773 MFG Part Number 74008880
Yes those look like the correct numbers. |
