My dryer doesn't blow any hot air. I was checking through these forums and also watching some of the videos on this site and I realize there are a few parts that could cause this. So I was hoping someone could help me pinpoint the part I need? - The dryer spins. - It blows air (not hot). - It never stops running, whether it be on timed dry or not. - On timed dry it does time down to the end, but doesn't shut off.
Hope this helps?
Just so everyone knows I figured it out. When I took the heating element out, I lightly wiggled each coil and found one of the coil wires had snapped. Hopefully this will help the next person:)
