DahMurf
#1 Posted : Thursday, June 6, 2013 7:57:29 AM(UTC)
DahMurf
When the washer is 1/2 full or full of clothes & water (med or large setting) it won't start to spin. (There are 2 points in the cycle that it tries to do this. After the wash cycle and at the end for the final rinse) It sounds like it's trying to spin but doesn't. If I push the knob off and back on without changing anything it starts right up however it seems a bit slow and weak. It does seem that by the end of the spin it's up to full speed.
I've read this is likely an issue with the clutch but I'm hoping someone familiar with this washer & this issue can advise what would be the best place to start, item(s) to inspect/replace/repair. I'm hoping I don't have an issue with the control knob too!
The lid switch broke but we just bypassed it. (Don't worry we don't have any little kids in the house! :D )
We just replaced the direct drive washer pump as it was leaking.
Now that we've been under there we're hoping to do whatever final repair is needed at one time rather than having this thing apart for a week or two swapping parts!
I'm hoping to limp this washer through another 2 years before needing a completely new unit!
Thank you in advance for any assistance! :)
Debbie
fairbank56
#2 Posted : Thursday, June 6, 2013 8:51:44 AM(UTC)
fairbank56
Groups: Expert
The washer should not go into spin with the tub full of water. It should completely drain first, then the motor should pause for a few seconds and then start again. At that point, it should start to spin while still draining. If it's starting to spin with tub full of water, the neutral drain mechanism in the gearcase is faulty. If the motor doesn't pause after draining, the timer is faulty. An intermittent spin with no water in tub is most likely a clutch problem.
Eric
