rojoverde
#1 Posted : Wednesday, June 5, 2013 7:33:53 AM(UTC)
rojoverde
Bought a used stackable. Note, there is some cosmetic damage on the sides close to the bottom. Maybe dropped?
Wash cycle on all setting works fine, hot/cold works fine. When it gets to the rinse cycle it makes all the right noises but does not put water into the drum. Subsequently, no rinse and no spin. Does not work on quick rinse or spin only cycle either.
Took off and tested the pressure switch, tested ok. When I put it back on it actually did a rinse and spin. Then nothing.
Tried it again and was able to do a quick rinse and spin, then nothing. Is the pressure switch out even though it shows good? Is it the board?
If we get cold water in the wash cycle, would that eliminate the valve as a potential problem?
sidfink43
#2 Posted : Friday, June 7, 2013 3:16:48 PM(UTC)
sidfink43
I am not familiar at all with this model, which is probably the same for most of the folks who reply on this site (we are volunteers who are experienced in the repair business).
So I can only speculate, which is that since it will go through the wash cycle ok it probably is the control unit.
Good luck, hope this helps.
