avenger619
#1 Posted : Monday, June 3, 2013 10:52:42 AM(UTC)
avenger619
New here;
Hi guys first of all I want to thank for any help I can get.
My oven currently is not working, I have done some research online and came to find out that my oven is an electric ignition. I have also revised forums for answers, I could use some help to really pinpoint the culprit before I go off buying expensive random parts.
Here are the symptoms:
1. No ignition or lighting noise when set to bake. Only Digital screen stays at pre heat option.
2. No gas flow or smell of gas released, I tried lighting manually and nothing. (keep door button closed during test)
3. I disconnected back panel and disconnected and reconnected wires such as bake sensor & control module ect to make sure connections were properly making contact.
4. Unplug stove and re plugged after 15-20 minutes, and nothing.
5.Yes,top stove igniters do work.
6. Did a error code test on screen and no F# codes were given.:confused:
7. Yes, cooktop lock option is unlocked.
8. Tested Broil and it does click and light up right, I see the flames inside the oven door, so seems like the bake is the only thing not working properly.
Can anyone suggest what other things to look for to narrow it down?
avenger619
#2 Posted : Thursday, June 6, 2013 8:32:27 PM(UTC)
avenger619
anyone? help will be much appreciated
