pilotem
#1 Posted : Friday, May 31, 2013 8:46:43 AM(UTC)
pilotem
Hi every one
My washer stop working properly suddenly after few years
When we start the washer, it fill correctly but that's it
Don't spin and don't drain
I chek the lid switch and replace the fuse, that's suspecting me the source of the problem
Do someone know if the timer runs normally whit a damage switch or not
Because the timer doesn't move forward equally
Some Q's ...
M
fairbank56
#2 Posted : Friday, May 31, 2013 9:27:38 AM(UTC)
fairbank56
Groups: Expert
Washer would not fill if fuse was blown. Timer should start advancing after fill stops. Will it drain/spin and advance timer if you manually advance timer to spin? If not, unplug washer, remove front panel, check continuity from power plug hot (narrow blade) to yellow wire (from timer) at drive motor with timer in on position. If no good, likely fault with lid switch.
Eric
