andrewa124
#1 Posted : 16 years ago
andrewa124
I woke up to find my dispoal only hums. I looked down the sink and it seems to be jammed with some stuff. I tried clearing it a bit, but not too sure if I should put my hand down there (I happen to like my fingers). I tried the reset switch but it does not click. Any Advice would be awesome.
#2 Posted : 16 years ago
In the center of the bottom plate is a hole for a special wrench which comes together with a garbage disposal. You can unjam the garbage disposal using this wrench.
andrewa124
#3 Posted : 16 years ago
andrewa124
I just got finished doing that and it worked.
#4 Posted : 16 years ago
I'm glad you were able to fix it.
