I have a LG Steam Washer model WM3001HWA. About 2 weeks ago it started making grinding noises when spinning fast. Ten days later the tub does not spin anymore (it does spin if I rotate it manually, though). No error message other than "unbalance load" (just one time). I basically took the whole damn thing apart and found that the back bearing is a bit rusty and there is some rust leaking out. I just bought the 2 bearing balls plus seal hoping that replacing these parts will solve the problem. Any comments/suggestions? Any other part I should buy? Thanks!
A.
How did you get the top cover off?
