kevinheadd
#1 Posted : Tuesday, October 6, 2009 9:47:37 AM(UTC)
kevinheadd
THIRD TRY, GAVE YOU THE WRONG MODEL # .ICE MAKER WATER KEEPS COMING OUT WELL AFTER THE ICE TRAY IS FULL. AT LEAST TWICE AS MUCH CAUSING EVERYTHING TO BECOME ONE GIANT ICE CUBE IN BIN. THANKS IN ADVANCE.
KEVIN H.:confused:
applianceman
#2 Posted : Tuesday, October 6, 2009 7:40:55 PM(UTC)
applianceman
The water valve is most likely the problem; look in the tube that comes into the icemaker to see if it is clogged with ice. If it is clean all the ice out before you change the water valve. There is a chance the icemaker is causing this but it is unlikely. GE Icemaker Repair Guide
Water Keeps Coming (Refrigerator & Freezer Repair)
by kevinheadd 10/6/2009 8:56:48 AM(UTC)
