flasch
#1 Posted : Tuesday, October 6, 2009 7:18:51 AM(UTC)
flasch
My Hotpoint Counter Saver Plus will not turn on. I have checked the breaker and it is not tripped. Any body know of a reset?
applianceman
#2 Posted : Thursday, October 8, 2009 11:06:01 AM(UTC)
applianceman
The fuse may be blown. Remove the font griddle then the control panel. Once the control panel is off you should see a fuse. You can check this fuse with an ohmmeter but if you don’t have one just replace it because it is most likely your problem. Microwave Repair Guide
flasch
#3 Posted : Thursday, October 8, 2009 11:15:20 AM(UTC)
flasch
Thanks. Worked out perfectly. Thanks again
