Mzjazzy28
#1 Posted : Thursday, May 23, 2013 1:15:41 PM(UTC)
Mzjazzy28
My fridge is only 2 yrs old and my fridge compartment area is warm along with the freezer is warm. It made a vey loud noise then all of a sudden everything was warm. The refrigerator is on but no cold area is coming out in either of the compartments. Does anyone know what this could be?
Simon / APP Team
#2 Posted : Thursday, May 23, 2013 2:36:52 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
If you own a multimeter remove the compressor cover at the rear bottom of the fridge. Locate the inverter board attached to the compressor and with fridge turned on check if there is 120VAC at the Black and Red wire disconnect plug.
If it is proper voltage - most likely you should replace the inverter
Part number: 241577505
Here are the breakdown diagrams and System parts for Frigidaire LGUB2642LF0 - AppliancePartsPros.com
Please, post the results.
Simon.
