When the motor is running, my fridge makes a high pitched, tinkling sound. What is this? Can it be fixed?
Groups: APP Team
Hi. Open a freezer door and check if that noise is coming from the evaporator fan behind the rear panel? Here are the breakdown diagrams and Liner parts for Whirlpool ET18NKXFW02 - AppliancePartsPros.comThe motor is #10 on the diagram. If the noise coming from behind the cover, remove it and check for ice build up. Post the results. Simon.
Thanks for the tip, Simon!
Lisa
Groups: APP Team
