Jcowin
#1 Posted : Monday, May 20, 2013 8:09:17 AM(UTC)
Jcowin
I have a JennAir oven control panel that some of the functions did not respond at all . I have replaced the touchpad but some functions still do not respond when touched.
Simon / APP Team
#2 Posted : Monday, May 20, 2013 10:08:08 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
In the case like yours when the touch pad already been replaced but some keys are still not responding you should replace the clock assembly/oven control board Part number: 71001799
Before doing that check the flex ribbon connector for cracks.
Here are the breakdown diagrams and Control Panel parts for Jenn-Air WM30460B - AppliancePartsPros.com
post the results.
Simon.
Jcowin
#3 Posted : Monday, May 20, 2013 10:45:56 AM(UTC)
Jcowin
Thanks Simon, I'll order the part.
Simon / APP Team
#4 Posted : Monday, May 20, 2013 10:54:46 AM(UTC)
Simon / APP Team
Groups: APP Team
My pleasure.
Jcowin
#5 Posted : Friday, May 24, 2013 3:57:32 AM(UTC)
Jcowin
Simon,
Bad news I have installed the clock on the oven still many buttons do not respond.
John
Simon / APP Team
#6 Posted : Friday, May 24, 2013 12:58:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is no miracles. If you replaced the touch pad and the ribbon is good and connected properly and the control board is new you should not have the same problem. Check all connections.
Are the same keys doesn't work?
Simon.
Jcowin
#7 Posted : Tuesday, June 4, 2013 3:01:41 AM(UTC)
Jcowin
Simon,
Here are some more details on my oven , the fan runs and the oven light are on constantly . The bake,clean,probe and all of the buttons on the left do not respond ie: clock,temp,timer .the only buttons that respond are the Broil, Con roast. Is the temp sensor in the oven a possibility ?
Thanks,John
Simon / APP Team
#8 Posted : Tuesday, June 4, 2013 3:33:02 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What do you mean when you say "the buttons do not respond"? The clock won't display the function or the oven won't bake, self clean, etc?
What is the part number of the touch pad (membrane) that you have replaced?
Simon.
