RFONES
#1 Posted : Thursday, May 16, 2013 6:55:29 PM(UTC)
RFONES
Need Your Help. I Can't Figure Out What Is Wrong With My Dryer, I Have Replaced The Motor, Same Problem. Then I Replaced The High Limit Switch Three Days Later, Same Problem. Ordered Heating Element Same Night Thinking That Replacing Both Of Those Parts That Would Take Care Of It! No.then Ordered The Cycling 1 Thermostat And The Belt Tensioner Pulley Because I Thought It Was Over Heating The New Motor. Still Same Problem. Any Ideas?:
Simon / APP Team
#2 Posted : Thursday, May 16, 2013 8:09:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What do you do to restart the dryer? Will it start right away or it takes some cool off time?
Do you have a multimeter, are prepared to do some testing?
Simon.
RFONES
#3 Posted : Thursday, May 30, 2013 5:35:15 PM(UTC)
RFONES
When We Start It When It Is Has Not Been Running For A While, Like Overnight,it Will Start Right Awayand Run For 20 Minutes Then Stop. Once It Cools Down For At Least 20 Minutes It Will Start Back Up , But Only Runs For About 10 Minutes At A Time.
And Yes,i Do Have A Multi Meter.
Ross
