I hv Whirlpool quiet partner II dishwasher. Lock light is on so i assume power is ok but when i select cycle/option button no light comes on but lock light blinks. When i push start button lock light blinks on/off 3/4x than start button blinks on but stops when i let go but washer doesnt start & lock light comes back on. Ive tried couple reset codes but didnt work. Is there possibly something wrong with the control panel? Please help
Sounds like your controls are locked. There should be a button on there that you hold down for 3 seconds and then the lock light should turn off.
Groups: APP Team
Hello.
If you press and hold for four seconds the "Heated Dry" button the control should unlock.
Post the results.
Simon.
It worked! Ur a genius! I had a plumber out here to look at it & he culdnt figure it out. Thank u so much!
Groups: APP Team
You are welcome. If you would call a nuclear physicist he probably won't be able to solve this either. For the future references you should have this information in the owners manual.
Simon.
Glad you figured it out. I get so many calls about this.
Yeah i was gonna look in the manual but unfortunately it got thrown out during our move into the house. Guess i need to get another one. Thanks again!
