HotPepperFan
#1 Posted : 12 years ago
HotPepperFan
The griddle on my Thermador PCS484 cooktop will only heat if the control knob is set to the highest temperature position (and sometimes not even then).
Once lit (with control in highest temperature position) if the knob is moved to a lower set temperature, the ignitor goes off and the flames extinguish.
Ignitor is "glow" type (not spark).
What parts do I need?
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hello.
Based on the information you provided the griddle thermostat is damaged and should be replaced
Part number: 415004
Part number: 415004
Assuming that the complete model number of the cooktop is PCS484GD here are the breakdown diagrams and 18-Burner Box parts for Thermador PCS484GD - AppliancePartsPros.com
Post the results.
Simon.
