My gas centennial has stopped drying things? It seems to not be getting hot. I had it on Automatic dry (high heat) under energy preferred setting, came to switch about 2 hours later and was still on same setting and clothes were cold and damp?:confused:
Groups: APP Team
Hello. You would need a multimeter to run the tests. if you have one - buckle up! Remove the rear cover from the dryer and locate thermal fuse Part number: 3392519
Pull one wire off and check continuity. If it's open (no continuity) - replace the fuse and make sure that entire exhaust system is clean. Next check the thermal cut-off and limit thermostat Part number: W10480709
