billda
#1 Posted : Tuesday, May 14, 2013 4:42:45 AM(UTC)
billda
THe freezer coils are freezing up. I first replaced thermostat sensor and defrost sensor. Still froze up, so I tested and replaced the bad Defrost element. Still froze up, so I replaced the main circuit board. STILL FREEZING UP!!! HELP!!!
#2 Posted : Tuesday, May 14, 2013 3:52:57 PM(UTC)
Hello,
Does the fan in the freezer work properly?
If it does, pull the refrigerator out of the wail and unplug it. Remove the cover from the main control board. Remove the wire from the J9 terminal and measure the resistance between this wire and the neutral wire connected to the J7-9 pin. The normal reading suppose to be about 22 Ohms.
Post the results.
Which parts did you call "thermostat sensor" and "defrost sensor"?
Here are the breakdown diagrams and Parts for GE PSS27NHMCCC Refrigerator - AppliancePartsPros.com
