Hi
Here's the deal why dishwasher was making a loud vibrating noise during the draining process so I removed several parts and got the the impeller the strainer and the Chanel's where the check ball is located we're filled with left over soap build up and what not 10 years worth so I cleaned all out and put it back together that made a huge difference but now the dishwasher doesn't cycle through all it's stages and won't stop,one thing that is different is that the spray impeller broke off a small piece,any advise would be appreciated. David
Originally Posted by: Press68  ...now the dishwasher doesn't cycle through all it's stages and won't stop... Hi David, Please explain it more detailed. Also, if the wash impeller broken, you have to order the complete drain & wash impeller kit. It comes with the installation instructions. - The drain & wash impeller kit Part number: 675806
Hi Gene I can manually turn the timer to make the cycles continue but it stays about the two or three o'clock area and stays in the run cycle it gets really hot and even melts and disforms some plastic glasses due to the run length it will drain when i put it in that cycle so I am not sure if that helps at all. Thanks David
David, In such situation it is possible that the timer is the culprit. - The timer Part number: 8535369
