jd101
#1 Posted : Sunday, May 12, 2013 1:15:57 PM(UTC)
jd101
Recently my dryer stopped generating heat when drying clothes. All fuses are fine on the main circuit board, so I suspect the thermal fuse on the dryer itself has probably blown. We haven't vacuumed out any lint build up over the years so it's the part that seems most likely to have failed. I'm trying to perform a continuity test on the fuse, but I can't seem to disconnect the fuse from the leads no matter how hard I tug on them. The leads use some sort of connector so I'm wondering if they're "locked" onto the thermal fuse terminals?
I've attached a picture of the fuse with leads connected. Can anybody advise how to disconnect these leads? It used to be so simple ...
Thanks.
jd101 attached the following image(s):
#2 Posted : Monday, May 13, 2013 2:30:34 AM(UTC)
I cannot find info on a WED9400SBo2.
The following are for a WED9400SB0. It should be a close match if not exactly the same as your unit.
Following are your parts
Parts for Whirlpool WED9400SB0 Dryer - AppliancePartsPros.com
I cannot tell if the connector is the lockable type or not from the picture.
Hopefully someone else knows.
In any case it probably will not matter.
If this is the thermal fuse from the blower assembly then it would kill power to the motor.
To kill power to just the heating coil a thermal cut-off (fuse) is used. It is item 47 in the Bulkhead Parts section.
Before checking anything else I would check the power to the unit.
The heater requires the full 240 volts, everything else runs off of 120 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Blue"]Be careful as 240 volts is lethal !!![/COLOR]
Handles attachments
WED9400.pdf (636kb) downloaded 8 time(s).
appliance dude
#3 Posted : Wednesday, May 15, 2013 3:22:33 PM(UTC)
appliance dude
About getting those wires off. Just use a flat tip screwdriver. Slide the tip between the thermal fuse and connector and twist it and it should pop off. But if your dryer still tumbles then that is not the problem.
