etn
#1 Posted : Sunday, May 12, 2013 12:35:55 PM(UTC)
etn
How do you get access to the electronic control panel?
Simon / APP Team
#2 Posted : Monday, May 13, 2013 10:42:34 AM(UTC)
Simon / APP Team
Groups: APP Team
HI.
To access the control panel:
-unplug the unit
-pull the range forward so you can access the two end cap screws
-remove the two screws from the sides of the left and right end caps
-open the oven door and remove the two screws from the bottom of the control panel (at the ends of the touch pad)
pull out the bottom of the control panel, unclip the top edge from the bracket, and rotate the control panel forward and down so you can access the components.
I hope that helps.
Here the breakdown diagrams and Control Panel parts for Whirlpool RY160LXTS0 - AppliancePartsPros.com
Simon.
etn
#3 Posted : Monday, May 13, 2013 4:41:19 PM(UTC)
etn
Thanks for the info. I am going to replace the complete electronic control panel, will your instructions let me remove the panel?
Simon / APP Team
#4 Posted : Monday, May 13, 2013 4:49:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Yes, you should be able to remove the panel after it's taken out.
Simon.
Electronic control panel DOA (Oven Repair (including Ranges and Cooktops))
by marybeebee 1/28/2013 11:45:38 AM(UTC)
Frigidaire D/W electronic control panel (Dishwasher Repair)
by sscarpenter 12/29/2011 8:35:14 AM(UTC)
How do I replace the electronic control panel? (Washer Repair)
by AWC 9/7/2011 9:12:30 AM(UTC)
Range/Electronic Control Panel zapped... (Oven Repair (including Ranges and Cooktops))
by m---e 6/22/2008 5:37:06 PM(UTC)
Need electronic control panel for wall oven (Oven Repair (including Ranges and Cooktops))
by tankersm 12/27/2007 6:54:19 PM(UTC)
