Upbeat
#1 Posted : Tuesday, April 30, 2013 7:32:40 AM(UTC)
Upbeat
I had the oven preheating and heard the circuit breaker pop loudly. Now the range looks dead, no lights, nada. I waited, reset the breaker, placed the mini line tester against the electrical cord coming out of the wall and found the line is live. (I'm afraid to put that tiny little device right into a 220 outlet.) I unplugged the range and plugged it in again but it is still dead.
BTW, I installed a microwave fan a few years ago and cut into the live 220 going to the range. Yes, I'm a bonehead. :( It was some time ago but I think I cut just a few strands of the thick copper wire before all the sparks and smoke lead me to believe something was wrong. I repaired the line as well as I could and carried on. I'm guessing this may be a future problem although losing computers and appliances has been routine with the power fluctuations and outages in our area.
Any advice other than "try not to kill yourself" is greatly appreciated.
#2 Posted : Wednesday, May 1, 2013 3:32:54 AM(UTC)
Your model number seems to be missing several digits at the end of it.
Sears/Kenmore model numbers are usually 3 digits, a period and then another eight digits.
Also I am not sure what you mean by "microwave fan"
Is this an above stove microwave that also includes an exhaust fan?
If it is then this is definitely a bad situation.
Microwaves pull a fair amount of current and although not part of most electrical codes it is advisable to have them on a separate line.
Also depending on the type of microwave they can cause spikes on the line as the magnetron turns on/off.
I do not know what type of mini line tester you are using but if it is one with just idiot lights then in my opinion it is pretty useless especially when working with a 240 volt circuit. Get yourself a proper multimeter and then check the power.
You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Guest (4)
