hello i am having a problem with my dryer,it is making noise anytime i put heavy loads and it is not the belt because it was changed recently, maybe a few months ago.can anyone please help and give me there opinions on what it can be. Thank you
A model number may help others help you.
Also it depends on what kind of noise.
Sine the noise is dependent of load weight it is probably related to the drum support parts.
Many units use glides (teflon/plastic strips) to support the front of the drum. A scraping noise is often an indicator that they need replacing.
Most Whirlpool units use support wheels for the back of the drum. Often a thumping noise is an indicator that they are shot. But may also be squeaking etc. if the wheel bearing or shaft are worn. |
THIS FORUM IS DEAD!!!!!!! |
