So tonight in the middle of a cycle my wife opens the door to our dyer to add more clothes. upon doing so when she pushed the button to start it back it would not. Reading other posts I tested thermal and it works the door switch clicks and the start switch does as well breaker checked have no idea where to go from here any suggestions?:confused:
A model number may help others help you.
How did you check the thermal fuse and the breaker (power)? With a meter?
Also just because a switch clicks does not mean that the contacts inside the switch actually close. |
THIS FORUM IS DEAD!!!!!!! |
