CSRedden718
#1 Posted : Saturday, April 27, 2013 12:09:01 PM(UTC)
CSRedden718
Attempting to replace an infinite switch on my Kenmore electric range. I've already removed the old (bad) infinite switch.
I've consulted the wiring diagram and know where 3 out of the 5 wires need to be connected to the new switch but am unsure regarding the two wires that go to the actual burner element (H1, H2).
These two wires are the same color (yellow) and I'm not able to tell them apart. The wiring diagram is not helpful in regards to this either, as both wires are labeled the same (y-10) here as well.
For reference, the wiring diagram for my stove is part #: 316255162
Can anyone tell me whether or not it matters which of these two wires is connected to which (H) terminal is important? Or would I be o.k. as long as they're both connected to either of the (H) terminals and not something else?
Thank you in advance!
