IT DRY'S FOR THE FIRST 5 MINUTES THEN IT STOPS HEATING I CLEANED IT FROM ALL LINT AND NO PASSAGES ARE BLOCKED GOOD AIRFLOW
MAY YOU PLEASE HELP AND IF THERE IS A PART THAT IS DAMAGED MAY I HAVE PART NUMBER OR NAME TO BE ABLE TO PURCHASE THANKS:mad:
Originally Posted by: maddogg13 IT DRY'S FOR THE FIRST 5 MINUTES THEN IT STOPS HEATING I CLEANED IT FROM ALL LINT AND NO PASSAGES ARE BLOCKED GOOD AIRFLOW
MAY YOU PLEASE HELP AND IF THERE IS A PART THAT IS DAMAGED MAY I HAVE PART NUMBER OR NAME TO BE ABLE TO PURCHASE THANKS:mad: Have you observed that the ignitor comes back on without producing any flame? If that does occur, good chance the coils are bad. You may want to look at the below parts breakdown and look under the burner section. Model LGB6300LW0
Originally Posted by: Frank / APP Team Have you observed that the ignitor comes back on without producing any flame? If that does occur, good chance the coils are bad. You may want to look at the below parts breakdown and look under the burner section. Model LGB6300LW0
THE COIL CLICKS ON AND THERE IS A BRIGHT YELLOW, ORANGE COLOR THEN ABOUT 15 SECONDS LATER IT CLICKS OFF NEVER TO TURN ON ONCE AGAIN
Originally Posted by: maddogg13 THE COIL CLICKS ON AND THERE IS A BRIGHT YELLOW, ORANGE COLOR THEN ABOUT 15 SECONDS LATER IT CLICKS OFF NEVER TO TURN ON ONCE AGAIN If the ignitor never comes back on you might suspect the below part. It's one of the parts that come into play for proper ignitor operation. Part number: AP2910747
