AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
water frozen in the bottom of the frig& water gets under the frig. on the freezer sid
I have noticed water under the frig.on the freezer side,when I tried to find where it might be coming from,I found frozen water at the bottom of the freezer,I revmoved the ice bucket checked the water inlet,it looked to be ok,I have turned the ice maker off,and there is water still coming from under the frig.onto the floor.I have replaced the ice bucket,this hasnt solved the problem.What might be the problem?I was told it might be a defrost problem????? Thanks for any help.:confused:
you have a stopped up defrost drain. pull out bottom basket, look at the rear of the freezer section just below the panel. you should see a drain hole. the area around it will be frozen. you must open the drain. use hot water to melt the ice at the drain tube. most likely you will have to go behind the ref. and take the back panel off and the obstruction will probably in one of the curves.
the reason for the water is that when the box goes into a defrost the frost is melted of the coils and should drain in a pan under ref. when it can't drain the water builds and freezes under your basket. when the ice get's thick enough the defrost water runs over the ice and out the door. probably happens about twice a day. icemaker o.k.
