The dishwasher starts, then a couple minutes into the cycle it stops. The Sensing, washing dhying and sanitizing lights start flashing. There is some standing water in the bottom. Once you clear the lights and try to start again I can hear water being drained, so I don't know if it is the drain pump. Any ideas
sounds like the dishwasher is overfilling. the next time is stops, open the door and check water level. there is a float at the front left side of the dishwasher. push down on the float. if you hear a click then it has to much water and the valve needs to be replaced.
