Have numbers 014-62717 and 8299778 7186A11. Dryer does not heat up and just keeps running.
Originally Posted by: debjunelb Have numbers 014-62717 and 8299778 7186A11. Dryer does not heat up and just keeps running. Need to know what parts are needed to repair
Originally Posted by: debjunelb Need to know what parts are needed to repair Debjunelb, None of the numbers you supplied are a model or serial number for a Whirlpool dryer. We'll need a proper number to research the wiring diagram and parts diagram to advise you properly. If the dryer is an "Electric" 240 VAC dryer, you would want to check the breakers in the panel, and make sure both 30 amp breakers are reset and locked in position. If that isn't the issue, repost with a proper moodel number and we'll get you going.
