RJGHIA
#1 Posted : Tuesday, April 16, 2013 2:43:15 PM(UTC)
RJGHIA
Replaced Coils & Cycling Thermo, Tested Rest Of Sensors. Still Have Intermittent Heat. Ignitor Glows Draws 3.5 Amps. Can I Test The Current Through The Coils To See If They Are Being Fired? If So Which Leads Of The Coils Would Have Current At What Time? A Wiring Diagram Would Help Alot If There Is A Place To Get One. Thanks Rj
Simon / APP Team
#2 Posted : Tuesday, April 16, 2013 4:47:26 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide more detailed problem description.
How long the flame stays on, what happens then?
The tech sheet should be inside the control panel.
Here are the breakdown diagrams and Bulkhead parts for Estate TGDS840PQ0 - AppliancePartsPros.com
Simon.
