AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
dishwasher fills with water but does not work in wash cycle
The dishwasher will fill up with water, but it does not work in the wash cycle. No water is going through the spray arms. Once cancelled it will drain the water fine. You can hear a humming noise like it is trying to circulate the water. Cleaned the sump and used a dishwater cleaner and still not working. Thank you in advance for any help.
Hello, If the circulation pump motor makes a humming noise when the dishwasher is on washing cycle and there is no a foreign object inside the sump, the motor is bad. - The circulation pump motor Part number: W10239404
Dishwasher Repair
