Washing machine has been beeping for sometime now, the pause/stop botton won't work. Additionally, this morning while using it died midway through the cycle. Is it possibly the control board gone bad???
That is very likely. There are some tech notes if you lift up the top, but if you cannot put it into a diagnostic mode than it probably is the control unit.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My washing machine comes on for 10 sec then shuts off. I checked the water flow and screens. ok What is going on?
