I found a solution to our leaking Kitchen Aid Dishwasher. Sounds crazy but by accident, I turned the silverware holders around, so the tallest part is NOT against the door. NO MORE PROBLEMS. My husband tried to adjust and replace parts and we had a repair man out 2 times. It continued to leak, gush, out the bottom of the door. One day by accident I turned the silverware holders around and AMAZINGLY, the next wash cycle was perfect. That was 5 months ago and still no problem.
GOOD LUCK!
I found a solution to our leaking Kitchen Aid Dishwasher. Sounds crazy but by accident, I turned the silverware holders around, so the tallest part is NOT against the door. NO MORE PROBLEMS. My husband tried to adjust and replace parts and we had a repair man out 2 times. It continued to leak, gush, out the bottom of the door. One day by accident I turned the silverware holders around and AMAZINGLY, the next wash cycle was perfect. That was 5 months ago and still no problem. Read more: http://forum.appliancepartspros...rt-up.html#ixzz2QIQc37D3 http://forum.appliancepartspros.com
