I purchased a replacement blower wheel #Y303836 for my Amana lea30aw dryer. I also purchased a replacement motor. There is no way to attached the supplied wheel to the motor, nor can I find any additional parts on this site that would be required to make assembly of these two items possible. The old blower wheel was attached to the motor shaft with a threded connection (now stripped), but the replacement I purchased seems to be attached with a keyed hole and clamp. The hole in the center of the wheel isn't even large enough to fit over the motor shaft.
Please help, because either part is useless without being able to attach the wheel. Thanks, Paul
Evidently I managed to order the wrong part. I don't know how I switched dryer models on myself, but I surely did. I should have ordered #56000.
