We remodelled our kitchen and when finished, started up our fridge. However, it won't stay cool. It was only rolled from room to room. The fans and the compressor are working and cool air is coming out of freezer vent and little out of fridge vent. It seems like after a while the cool air is warmer. Any ideas, this fridge is less than 2 years old?:(
Hello, Remove the rear cover and front bottom grille. Using a vacuum cleaner and condenser cleaning brush, clean the condenser coils. Make sure the fan next to the compressor and the fan inside the freezer are working properly. Wait a few hours after cleaning the condenser coils to see if it helped. Post the results. - The condenser cleaning brush Part number: 4210463RW
