martyr
#1 Posted : Thursday, April 11, 2013 4:40:31 PM(UTC)
martyr
HI! I need to replace the entire door of our Frigidaire Micro Model number FMV157GC. I'm ordering the Door Assembly package...Just wondering...Do you have a video of a step by step? Does it start more or less, like the 'replacing handle video', by removing the choke to expose screws?
Otherwise, what paper instructions come along with the Complete Door Assembly Package? I have all the necessary tools, just questioning my Mrs. Fixit Abilities:/
Thanks for any response!
Marty:confused:
#2 Posted : Friday, April 12, 2013 12:46:34 PM(UTC)
Hi Marty,
First of all, the microwave has to be removed from the cabinet. The next step is to remove the outer case. The complete instructions are attached to the post.
Here are the breakdown diagrams and Parts for Frigidaire FMV157GCA Microwave - AppliancePartsPros.com
File Attachment(s):
FMV157G - Door replacement and disassembly.doc (476kb) downloaded 14 time(s).
Meha
#3 Posted : Wednesday, October 16, 2013 6:46:17 PM(UTC)
Meha
Hi, Gene, just wanted to thank you for posting the info. Once I figured out what to do, it took about 10 minutes to make the repair.
Also, wanted to note that you don't have to remove this microwave from the cabinet to replace the door. You just need to remove the louver, then you can lift the door out of the hinges. Easy!
