I have a frigidaire fdbl960bb0 and I'm getting no water to the top rack. I have pulled the drain screen and the pump inspection cover and there is no blockage. The spray arm is not blocked. Seems to be good pressure to the lower rack but bone dry up top. I started the machine with the door open to verify.
Any suggestions??
Thanks Ray
Groups: APP Team
Hi. You need to see if the Check Ball, located inside the circulation pump is OK and nothing is restricting it from moving in the channel.If all looks OK - replace the ball. The Check Ball Part number: AP2109095
