jmseva
#1 Posted : Wednesday, April 10, 2013 5:00:23 PM(UTC)
jmseva
Hello, My washer's agitator does not work. The washer drains and spins but does not wash. I have checked the air bell coupling and the teeth does not seem to be worn out. What do you guys think the problem is? Thx
jmseva
#2 Posted : Wednesday, April 10, 2013 5:03:27 PM(UTC)
jmseva
BTW - the washer just hums and produces a clicking like sound when trying to do a cycle.
fairbank56
#3 Posted : Wednesday, April 10, 2013 6:14:34 PM(UTC)
fairbank56
Groups: Expert
Remove the front panel and observe the motor pulley, belt and main drive pulley during agitate mode. If they are all turning and your sure the agitator coupler is ok, then the transmission is faulty. If the motor pulley is not turning (motor just humming) can you rotate it freely by hand in the CCW (viewed from below) direction with the belt and main drive pulley also rotating with it? If not, the transmission is faulty. If yes but the motor just hums during agitate, the timer may be faulty but I would need to see a clear photo of the wiring diagram to be sure. I don't have the tech sheet for your washer. It is located behind the control panel.
Eric
