So I have a fairly new Frigidaire Dishwasher (FDB1502RGC0) that's less than 3 years old. Starting yesterday, when we run it, the wash cycle never stops. It just keeps running and running and running (we let it run once up to 6 hours). Once we hit cancel, it will drain the water out and stop. But it will never move onto the next step in the cycle which should be drying... Any thoughts on what might be broken and hopefully can be fixed/replaced. I am hoping its the circuit board, but that's a total guess. Any thoughts would be appreciated.
I don't know if frigidaire dishwashers are anything like Bosch but mine did the exact same thing after about 3 years. There was a circuit board on the front of the appliance with one little burned out contact clearly visible even to a novice like me. The circuit was supposed to trigger the heating element, once broken, it would wait for ever thinking the water would heat up soon. I added a dab of solder, re-assembled and it worked fine for another 5 years. At least till my circulation quit, not as simple. Hmm, been a week, I suppose you may have this resolved by now
