2 Pages<12
#11 Posted : Friday, April 12, 2013 6:26:44 AM(UTC)
The lower current trip out rating of the 3 n 1 you have will cause problems and trip out during normal operating currents, but this will be a short amount of time. You might have other problems in the fridg if it stops working. Voltage tests would confirm.
OlaS
#12 Posted : Tuesday, April 16, 2013 8:29:06 AM(UTC)
OlaS
Thank you so much for your help and explanation.
I got the OEM relay for this model and installed it. Worked like a charm!
The compressor started and the freezer temperature stabilized around 0 +/- 5 degrees as designed by the manufacturer!
Great having such a professional team here to help.
Ola
Guest (5)
2 Pages<12
