this dryer is makeing sqeeking noise when in use i need to know how to open to see what is making noise if any one help and send diagram to open.
Thank you.
Them slopeheads are a bit tricky. The door must come off. The u shaped "Goalpost" front panel pops off. Then you can remove the clips holding down the top and get to the front glide mount and filter housing. It seems complicated but it really ain't. It is all in knowing the trick.
i will try to open. Thanks for the quick response.
