northmp
#1 Posted : Monday, April 8, 2013 2:49:52 PM(UTC)
northmp
I have an Inglis washer Model # IJ42001 which works fine until the rinse cycle. Then it will not drain and rinse or spin. I can turn it to a different cycle, like the gentle cycle to get it to work sometimes but takes a lot of playing around with it. What does it need for repair? Thanks.
fairbank56
#2 Posted : Monday, April 8, 2013 4:08:09 PM(UTC)
fairbank56
Groups: Expert
In regular cycle, after agitation stops, does the timer continue to advance on it's own? If it does as it should, you probably have a faulty timer. If it does not advance, it could still be the timer but might be the lid switch.
Eric
Inglis Washer - Buzzing, but not spinning/agitating (Washer Repair)
by fsuedonkey 10/19/2017 2:32:58 PM(UTC)
Inglis Washer Banging (Washer Repair)
by fsuedonkey 6/12/2015 6:09:36 AM(UTC)
Inglis Washer Shredding Gasket? (Washer Repair)
by Dargon 12/17/2012 5:56:47 AM(UTC)
Inglis Washer-Won't fill with water? (Washer Repair)
by Nancy10 11/5/2010 8:33:07 AM(UTC)
Inglis washer issue... (Washer Repair)
by Quentin 9/24/2010 2:21:46 PM(UTC)
Inglis Washer (Washer Repair)
by lostchild 6/8/2010 5:58:47 PM(UTC)
Inglis washer overfills and cycle does not start (Washer Repair)
by jorbal 11/26/2009 6:55:32 AM(UTC)
Inglis Washer won't stop filling (Washer Repair)
by Col Flag 1/24/2009 10:04:51 AM(UTC)
