personalt
#1 Posted : Monday, April 8, 2013 11:15:33 AM(UTC)
personalt
My gas valve coils keep failing. i have replaced them twice in the past 6 months. is there anything that would be a likely cause of pre-mature failure?
Problem the last two times was no heat. I remove and repalce the coils and it works fine for a few months. I thought maybe the 1st replacement set going bad was just a fluke. Now that the second set went bad I am trying to determine if there is another cause.
Frigidaire 5303931775 Coil Kit (gas Valve)-2 Coils - AppliancePartsPros.com
