I am having trouble with the water draining in the sink when I turn the disposal on. It is backing up and coming up through the other basin (not the one with the disposal) I assume this a valve issue in the dishwasher but not sure. Any help would be great.
Did this unit used to run OK with the current plumbing set up or is this a new installation?
Odds are that there is a house plumbing problem re: the P-trap is partially plugged. |
THIS FORUM IS DEAD!!!!!!! |
