Just replaced timer on washing machine because the old timer was advancing but not putting the laundry through the cycles properly. Now the new timer is not advancing, and I must manually advance on each cycle. The old timer was working on all cycles except the one I use all the time which is the regular cycle. I can still wash clothes with the old timer but I must use the delicate or hand wash cycles, with my 2 small children Id prefer to figure this out. The new timer doesnt advance on any cycle. I hate to have a repair man come out if I could do it on my own, but Im kind of at a loss now as to what the problem might be. It doesnt seem mechanical because all the parts in the machine tub function, its just a matter of the washer not engaging or moving on to the next cycle as needed. Any advice would be greatly appreciated.
It sounds like the new timer might be defective. Take the timer back and exchange it . You can also try and put the old one back in and make sure it is working on the other cycles. If it works then it sounds defective if it dont you might have pulled some wires loose from the harness .
Yeah the one in there is the second new timer, I thought the first timer I got 2 weeks ago was defective so I got another new one. The 1st and 2nd new timers are both doing exactly the same thing. No advancement. Will sit on wash cycle till I advance it, all cycles till manually advanced. When I put the old time back in it advances on its own okay on delicate, hand wash, and easy care, but on the regular/heavy cycle the old timer advances but doesn't engage the machine to do the cycles...I'm perplexed. :confused:
Groups: Expert
What is the serial number of your washer and what timer part number are you using to purchase the new timer?
Eric
22291406sw is the serial number the part number to the new timer is 22001690
I didnt see a part number on the old timer. The new timer was sent to me twice by APP by giving the serial numebr and model number of the machine.
Groups: Expert
That is the wrong part number. You need part number 22002185Eric
I am sending back the other 2 timers and I'm ordering the other part. Thank you so much for solving this issue! I will sleep so much better tonight! Thanks again
