During a 59 minute wash cycle the washer pauses after it stops spin out the wash cycle and right before it begins the rinse cycle always at the 13 minute mark. I have ran all of the tests and it passes each one, and it never shows any error code, I am totally lost on it now. please help...
Originally Posted by: Drizzt During a 59 minute wash cycle the washer pauses after it stops spin out the wash cycle and right before it begins the rinse cycle always at the 13 minute mark. I have ran all of the tests and it passes each one, and it never shows any error code, I am totally lost on it now. please help... Drizzt, Your first check should be the cold water supply faucet, fill hose and fill valve. Part number: AP4303282
The rinse cycle is a cold water fill, since you don't have an error code, and the test modes work, the next indication would be a failed or weak water solenoid, or intermittent water supply.
