Hi. New to forum and would greatly appreciate any help anyone can provide!
Water was spilled on the control button for our downdraft vent. The water was quickly wiped up and we tested the vent and it moved up and vent was working, but after about 30 minutes we were done cooking and the vent/blower wouldn't turn off and when we pressed the button for the vent to go down it wouldn't go down so we ended up pulling the power plug. We wiped the button again, took off the cover plate and there was a bit of water there and wiped that up as well. We then plugged the power plug back in and now it won't turn on. It's dead. Any ideas on what part might be broken and is it an easy fix? Thanks!
Originally Posted by: KAven  Hi. New to forum and would greatly appreciate any help anyone can provide!
Water was spilled on the control button for our downdraft vent. The water was quickly wiped up and we tested the vent and it moved up and vent was working, but after about 30 minutes we were done cooking and the vent/blower wouldn't turn off and when we pressed the button for the vent to go down it wouldn't go down so we ended up pulling the power plug. We wiped the button again, took off the cover plate and there was a bit of water there and wiped that up as well. We then plugged the power plug back in and now it won't turn on. It's dead. Any ideas on what part might be broken and is it an easy fix? Thanks! KAven, Did you recheck the fuses or breakers to see that they are properly set and supplying voltage to the vent system. Did you remove the cover plate at the bottom right corner of the main housing and check to see if the water had damaged the main control board or fuse ? And you'll need to check the filter switches they need to have an "open" circuit for the vent system to run. Under the circumstances, there's not a lot of "difficult" work involved. other than accessing and removing the panels inside the cabinet, under the counter top.
Hi Joe.
Thanks for the reply. Did check the fuse and it was fine, but didn't check the main control board. Is it in the small covered plate next to the blower? Thanks.
Originally Posted by: KAven  Hi Joe.
Thanks for the reply. Did check the fuse and it was fine, but didn't check the main control board. Is it in the small covered plate next to the blower? Thanks. KAven, Yes, the main control board is located on the housing, next to the blower, on the right hand side. The cover on the left hand side is the power connection / junction box. If you can supply us with an e mail address, we'll be happy to send you some illustarted informaton that may help.
Opened up the panel for the main control board and matched it with the diagram from my owner's manual and everything looks ok. No water, not electrical board burn marks. So I think the main control board is ok. I think the problem has something to do with the button.
Originally Posted by: KAven  Opened up the panel for the main control board and matched it with the diagram from my owner's manual and everything looks ok. No water, not electrical board burn marks. So I think the main control board is ok. I think the problem has something to do with the button. KAven, You're most likely correct, the motor switch Part number: AP4370582
could be damaged, but we're comfortable knowing some of the other possibilities are eliminated. Here's some help to access the switch assembly: 1. Raise retractable section to the up position. 2. Unplug vent or disconnect power. 3. Remove the filters. 4. Pull gently upward on the control cover (trim cap, the piece with the name plate)
to disengage the 3 ball connectors from the clips in the vent filter frame. 5. The motor switch housing is tucked behind the upper right filter frame. It is held in place by one screw.
6. Remove the screw and pull the switch housing from behind the frame. 7. The switch housing is held together by two screws, one on the front and one on the back of the housing. Remove the screws to gain access to the connections and circuit board. 8. Reassemble in reverse order of these steps."
How do you Raise retractable section to the up position if the power switch doesn't work to raise or lower the vent?
